Forum: VirtualDJ Skins
Topic: GTS-2K21 - Page: 1
New simple (for the moment :P) skin.
geposted Thu 16 Jul 20 @ 9:59 am
Do the initials GTS have a meaning? Get This Skin perhaps :-)
Ah, your initials...
I was too lazy to find a proper name for it... :P
hope your new skin has an option to turn off waves ;-) some djs like me see them as just taking up browser space. seeing my songs is the most important to me LOL
Hi George-
Great skin & excellent work !
one question about the Beatgrid lines & dots :
Is it possible to change in the .xml file the following :
The thicknes of the lines (all of them : beat 1-5-9 & beat 2-3-4) & also the size of the dots over them ( with 1-5-9 beeing thicker than 2-3-4)
can it be done ?
if yes where in the code to i have to look & replace it ?
i am attaching a picture of the areas that i would like to replace with the bigger ones.
thanks a lot
Search for:
<define class="wav_SCRATCH_HOR"
and
<scratchwave class="wav_SCRATCH_HOR"
Those are the elements you need to edit.
The width of the grid is easy, just edit <define class="wav_SCRATCH_HOR" and change
<grid mainsize="2" size="1"
to suit your needs
The height of the grid is more complex.
You need to edit <scratchwave class="wav_SCRATCH_HOR" and change (as an example)
gridpos="-5" gridheight="7"
Can you add Video menu?? This is a wonderful skin!!! Thanks
Yes, I'm working on it...
Additional to adding a Video menu can you also add a menu to choose a Waveform such as Mirror wave, Default wave, Scratch wave.??? Great Skin as always your hard work is Appreciated...Thanks.!!!
Ok just tried this skin and it’s my new go to 🤙🏾
Awesome job!!
Version 1.1.0 (pending review) added Video support.
My definitive skin! Perfect. Thanks
I love this skin and have it installed permanently. The one thing that I wish I could do is see the recording time on the top of the window. Is that something doable?
I record a bunch of 30 minute sets and have to rely on going to the preferences.
A new update is coming that has such an option.
Thanks so much for adding this option! It's a game changer!
New layout coming soon...
nice i see stem buttons :-)
Why is the jog circle so important to everyone? Is it really necessary?
There's so much can be do with that realestate.
That's why OSD layout exists (on the same skin)
49%
