As title says, will VDJ support the Hercules DJControl Inpulse 500? In the market between Numark Platinum FX and the Hercules controller, leaning towards FX due to VDJ support, but really interested in InPulse 500.
geposted Thu 16 Jul 20 @ 4:40 pm
https://virtualdj.com/download/
And then read the manual:
https://virtualdj.com/manuals/hardware/hercules/inpulse500/setup.html
geposted Thu 14 Jul 22 @ 5:36 am[ selected best answer by Adion on Thu 14 Jul 22 @ 5:36 am ]
Already supported:
geposted Thu 16 Jul 20 @ 4:44 pm
Thats great, not sure how I missed that.
geposted Thu 16 Jul 20 @ 5:04 pm
Is there a plan to buy it in a bundle?
geposted Thu 16 Jul 20 @ 6:26 pm
It's a Serato Lite / DJUCED controller. Does VDJ ever do bundles with controllers that are already bundled (and branded) with other software?
geposted Thu 16 Jul 20 @ 6:56 pm
My vdj is not detecting the controller (inpulse 500) is says disabled or custom mapping...please help
geposted Thu 14 Jul 22 @ 5:29 am
Make sure you get the latest version of VirtualDJ here:
Selected as best answer geposted Thu 14 Jul 22 @ 5:36 am
I cant download the last VDJ my windows is 32 bit i have the 8.2 version and i have active subscription but it did not connect i dunno wahts the problem( why it says disabled)
geposted Thu 14 Jul 22 @ 8:50 am
Normally the download page should show the 32-bit link if you open it from a 32-bit windows, but if not, you can get the latest 32-bit version from here as well:
https://virtualdj.com/download/build.html
geposted Thu 14 Jul 22 @ 9:18 am
