Hi, Has anybody used the Reloop Touch controller? And if so, what was your impression of it? Did you like it? Not like it? And why did you like it or not like it? Also, is the skin you are using on Virtual DJ, the same one that appears on the Reloop Touch screen? Or does the Reloop Touch Screen just have a default screen, that appears the same, no matter what skin you are using on Virtual DJ? Thanks, Scott
geposted Sun 19 Jul 20 @ 10:53 pm
The skin on the Reloop is a skin for the Reloop :)
What software skin you use is totally independent of what the controller has or look likes, and the display on the Reloop stays same no matter what software skin you use.
And default skin for the software, that most use, works with any and all controllers ;-)
geposted Sun 19 Jul 20 @ 10:54 pm
Okay thank you very much!
geposted Sun 19 Jul 20 @ 10:59 pm
