what would be the action to see the amount of separation ?
geposted Sat 25 Jul 20 @ 1:53 pm
`stems_bleed`
geposted Sat 25 Jul 20 @ 2:50 pm
thanks for your answer, but `stems_bleed´ doesnt show me the amount of separation, percent, i cant see on skin
geposted Sat 25 Jul 20 @ 2:58 pm
Where are you entering the script? You need create a text area on the skin, with that as the source. You can't just put it on a pad/button/knob and see text.
geposted Sat 25 Jul 20 @ 3:05 pm
@groovin actually you can if you use it as the button name, `stems_bleed` only shows when you have inst or vox muted or solo
@fer you haven't used exactly the same as I typed not sure what that second accent is but it's not the one I showed
geposted Sat 25 Jul 20 @ 3:47 pm
Oh yeah, so you can! Put it as the name, not the action. Doesn't work on a pad though.
geposted Sat 25 Jul 20 @ 3:53 pm
https://youtu.be/ybK4fGyyb5I
https://www.youtube.com/watch?v=ybK4fGyyb5I&feature=youtu.be
at minute 1: 50 you can see the percent (%) change , in my skin this is not happen
geposted Sat 25 Jul 20 @ 5:18 pm
yes it works on a pad too... but needs a solo or muted to appear too
geposted Sat 25 Jul 20 @ 5:20 pm
param in the stem pad shown in the video is map to stems_bleed and the name is `stems_bleed`
geposted Sat 25 Jul 20 @ 5:27 pm
Nicotux wrote :
works on a pad too
Yes, it was my fault. I put it in the Action box. I didn't notice the Name box.
geposted Sat 25 Jul 20 @ 5:41 pm
Thank you very much guys, the accent was the problem
geposted Sun 26 Jul 20 @ 9:35 am
