1st when you open VDj without hitting any buttons.Load song in deck 2 and the hot cue don’t light up on the controller until you hit the hot cues or switch pad mode and come back to hot cues.( only deck 2 does that ).
geposted Fri 07 Aug 20 @ 4:37 pm
still after updates:if you load in deck2 on a track there no hot cue light up until you go throw the pad mode aka hit one 1st ( roll, slicer, sample ) this only happen when you 1st open VDJ after you go throw the pad it will light up, deck 1 works right.
geposted Mon 21 Sep 20 @ 7:04 pm
