I posted the other day about an issue I’m having Looking for some ideas I’m running a MacBook Pro with High Sierra (yes I know it’s older os) I have this computer bootcamped so I can run windows as well this issue is on the Mac side
The problem I have I have the (A) key programmed to load deck 1 (A) deck 1 load I have the (B) key programmed to load deck 2
Deck 2 loads perfectly every time Deck 1 loads the first time when I press the A key then it will not load again It works perfectly on the windows side Is this a Mac issue? A High Sierra issue Or am I doing something wrong
Thanks
Thanks
geposted Sun 09 Aug 20 @ 9:23 pm
geposted Sun 09 Aug 20 @ 9:25 pm
It's a VDJ issue with high Sierra. Works fine on mojave is this something that can be looked at
geposted Mon 10 Aug 20 @ 9:35 pm
