Just wondering if anyone knows a code for autoplay to always be on even when virtual dj 8 closes and reopens,
this would be very handy for me thank you, I am using the code ;
<button panel="br" action="deck 1 automix">
to keep auto mix on
Any help would be appreciated to keep this button always on
Thank you
to keep auto mix on
Thank you
geposted Mon 10 Aug 20 @ 5:47 am
Keyboard mapping has a parameter "oninit"
Just add automix to the box.
Easy as that
Easy as that
geposted Mon 10 Aug 20 @ 5:52 am
Thanks for replying I have found an alternative to what I was looking for that works great :). I have made it so that the play button now runs auto play always on.
I do have an issue and have had it for a while now when I forget to load songs into the "Auto mix side-list" and press auto play or my play button it seems that all the songs that are in Track Browser will load into the side view (Auto mix) and then crash my deleting button on virtual dj 8 if the songs loading from the Track Browser could be stopped It much would be appreciated thank you
geposted Tue 11 Aug 20 @ 12:59 am
