how to make this FX , effect in the camera , looks like cartoon effect in real time
https://www.youtube.com/watch?time_continue=64&v=3uh42gY7zQ4&feature=emb_logo
geposted Mon 10 Aug 20 @ 3:20 pm
Its a Shader ;-)
VirtualDJ supports many thousands of shaders that you can use, to display visualizations, and some are a bit looking like cartoon as in the video ;-)
https://virtualdj.com/wiki/shadertoy.html
geposted Mon 10 Aug 20 @ 7:28 pm
He said "in the camera" - the overhead footage of your controller. It has some kind of edge enhancement.
geposted Mon 10 Aug 20 @ 7:35 pm
This isn’t in VDJ, is OBS or some other streaming soft. You can capture VDJ audio and Video to composite in layers and others sources in this kind of software.
geposted Mon 10 Aug 20 @ 7:41 pm
If you mean the camera view with the mixer, its just using the chroma key in the video
Look at the Camera FX settings
https://virtualdj.com/wiki/how%20to%20use%20camera.html
geposted Mon 10 Aug 20 @ 7:52 pm
Its VirtualDJ ;-) And VirtualDJ only...
Using video skin
See here : https://virtualdj.com/wiki/BroadcasterGFX.html
.png)
geposted Mon 10 Aug 20 @ 7:54 pm
Using video skin
.png)
Using video skin
.png)
Ok, my mistake. Never use this skin. Sorry.
geposted Mon 10 Aug 20 @ 8:47 pm
Then, the camera Fx may not be an effect “per se”, you can select a color for chroma in VDJ camera options, and its look like DJ select your own skin color and burn out with chroma.
geposted Mon 10 Aug 20 @ 8:51 pm
Maybe i was no Cleary with my sentences..
I mean the camera effects about the image in câmera , take a look at the hands ...for me is somekind of effect in the camera image, like x ray, neon or something like that...
I try tô find these in the manycam software but i csnt find an effect like that.
This vídeo is from /BroadcasterGFX.html
So its not from obs ir other software.
geposted Tue 11 Aug 20 @ 1:23 am
U was clear, and I believe is only the chroma setting of the camera. Try it. Select the skin color and slide the amount of the Fx.
geposted Tue 11 Aug 20 @ 2:52 am
