Why do we need an update every week?
I just allowed the update to run and my whole layout is messed up now, it's not the first time.
I will stop updating from now on
geposted Mon 10 Aug 20 @ 5:57 pm
what do you mean your messed up layout
geposted Mon 10 Aug 20 @ 6:26 pm
I like using the classic layout but it switched to another one, and when I changed back to classic I had to change a few things to get all the buttons right again.
Also the waveforms changed into other types in the top part and with the tracks.
It seems there are new options that change the track key to match with the other track, it's another thing I had to search to disable it.
I don't mind updates but it's a mess like this.
geposted Mon 10 Aug 20 @ 6:30 pm
you have to know when there are updates to correct bugs or to have new features.
then it's up to you
then it's up to you
geposted Mon 10 Aug 20 @ 6:38 pm
Since the first 64Bit version with steams ive updated several times and it has not destroyed anything on my (customized) skin.
geposted Mon 10 Aug 20 @ 7:27 pm
