made a virtual folder in 2021 non beta, tried to add music folders to it, than as I began moving it up my folder tree, the software crashes out. Immediately swapped to 2018 and did everything I needed. Lord, I really want to use the new version but I crash like this too often.
geposted Wed 12 Aug 20 @ 9:06 pm
You said you moved a folder "tree". Do you try to move a huge amout of files? What happens with single files, not folders or folder trees?
geposted Wed 12 Aug 20 @ 9:17 pm
VDJ Monty wrote :
I created a virtual folder inside a large folder of music. I grabbed and dragged the folder up the tree, stopping along the way to add music. after 30 seconds of doing this it crashed. Opened 2018 and did this for 30 more minutes with the same folder and made new virtual folders and had no problems.You said you moved a folder "tree". Do you try to move a huge amout of files? What happens with single files, not folders or folder trees?
geposted Wed 12 Aug 20 @ 9:55 pm
