I Have done a live test direct from virtual dj to Instagram using Yellow Duck as acceSs, but the video don't show correctly, because resolution. When I saw in window video in virtual works fine , but in Instagram the border is cut.
Any way to change the resolution stream?
geposted Fri 14 Aug 20 @ 11:31 am
You can change in settings.
Look for broadcastVideoQualityCustom where you can set ResX x ResY@videokbs, audiokbs
Keep in mind that most music videos/monitors/screens are 16:9, and so is VirtualDJ "defaults". (as well as Instagram broadcast being a bit of a "hack" with 3rd party tools)
If you are trying to broadcast "portrait" resolution, it might not look that good, depending on what you are using as video ..
geposted Fri 14 Aug 20 @ 2:43 pm
