I cant seem to figure out how to print a playlist. even when i look up setlist here it doesnt have an option for printing. Any help
geposted Mon 17 Aug 20 @ 9:03 pm
You can select the playlist in browser "lists & Advice -> " and display infos you need as columns in songs tab then use "Browser options -> Export browser view" as csv or html which are prinatble
geposted Mon 17 Aug 20 @ 9:23 pm
Ok I dont understand what you did there. I went to "list & Advice" found the playlist I wanted. then right clicked it , then went to export. it looks like it moved an entire copy of the songs I played all night into a folder. There was no option to make a CVS file. So I dont know how you got there
geposted Mon 17 Aug 20 @ 11:22 pm
Mark the playlist that you want export. Then move with the mouse to the browser options at the bottem left corner.
If its the history list, there is an other way. Go to:
C:\Users\<username>\Documents\VirtualDJ\History
and open the tracklist.txt
geposted Mon 17 Aug 20 @ 11:45 pm
geposted Tue 18 Aug 20 @ 12:11 am
can also see a little guide here:
The exported CVS file you can open in any spreadsheet program, like Microsoft Excel, Google Docs etc .. (both having free online versions).
And from there you can print.
geposted Fri 21 Aug 20 @ 11:36 am
