Ok guys got stem section working on my pads on ddjsx but I had to select factory settings in options.
Now my custom pad settings for my loops have gone .
How can I get both working at the same time cheers
geposted Tue 18 Aug 20 @ 3:54 pm
I have checked firmware and driver versions and I'm up to date as no new releases since 2016 on driver
geposted Tue 18 Aug 20 @ 4:00 pm
What you mean by custom pad settings for loop?
You made your own pad page? If so, it should be there at pad drop-down or right-click one of the 4 quick select buttons above the pads
geposted Sat 22 Aug 20 @ 1:25 pm
