The pad editor in VDJ isn't sufficient for my scripts anymore, so i'm generating pads and mappings externally now using NodeJS.
Is there a way to make VDJ reload the pad file(s), or just the current pad or something (using VDJScript)?
Right now i need to restart VDJ everytime, and it's a bit cumbersome.
geposted Sat 22 Aug 20 @ 12:26 pm
I think just switch pads would do it, or you could try this script
crash
crash
geposted Sat 22 Aug 20 @ 4:21 pm
LOL, 2 proposal of the use of "crash" in 2 days by 2 different crazy users ^^
the fact is.... it works ^^ ... with some side effects in windows size and positions and other temporary settings
better use "save_config & crash" even some lists orders are missed
geposted Sat 22 Aug 20 @ 5:43 pm
Haha! Ooh, that's dangerous knowledge.
Imagine you're at an event and the DJ leaves his post. The chaos you could cause with that.
geposted Sat 22 Aug 20 @ 5:59 pm
