Hey Guys Just wondering if there is a code for "playlist_load_and_remove" to delete a selected song
when i used the code ;
<button panel="br" action="browser_window 'playlist' & browser_remove & deck 1 select">
The auto mix button i have created loads the songs/files into the automix list this stops the code above and makes the code unusable until vd8 gets restarted
as-fore i would like the "playlist_load_and_remove" to delete a selected button as this button does not get stuck when the automix loads the files in
geposted Tue 25 Aug 20 @ 12:38 am
