Does anyone know if the Denon Prime Go works with VDJ2021?
geposted Fri 28 Aug 20 @ 7:41 pm
hello
Denon prime go is not native in vdj 2021
geposted Fri 28 Aug 20 @ 8:36 pm
This unit will probably never be supported by any Dj software.
It has currently no implementation for it, and unlikely to change
(Denon has stated this is just an ultra small unit for remote play, and sort of doesnt make sense to bring a laptop also then i guess :) )
geposted Fri 28 Aug 20 @ 8:39 pm
I just found this so hopefully, this will change:
https://djmag.com/news/virtualdj-now-support-denon-dj-prime-range#:~:text=Denon%20DJ%20has%20announced%20their,is%20now%20compatible%20with%20VirtualDJ.
geposted Fri 28 Aug 20 @ 9:33 pm
Well whoever wrote that has made a mistake by including the Go.
geposted Fri 28 Aug 20 @ 9:59 pm
Does it even send MIDI or have HID capabilities?
geposted Fri 28 Aug 20 @ 10:12 pm
The clincher is that it doesn't work with the Denon SDK which enabled all the other Prime units to work.
geposted Fri 28 Aug 20 @ 11:04 pm
