Hi,
what is the command for Customer-Button on the ROTARY CONTROLLER for HeadphoneGain 0%-100% ?
geposted Fri 28 Aug 20 @ 9:10 pm
question doesn't really make sense: headphone_gain is a start
geposted Fri 28 Aug 20 @ 9:15 pm
HeadphoneGain 0%-100%: headphone_gain
HeadphoneVolume 0%-100%: headphone_volume
HeadphoneMix 0%-100%: headphone_mix
HeadphoneCrossfader 0%-100%: headphone_crossfader
geposted Fri 28 Aug 20 @ 9:16 pm
headphone_volume
If I now want to put this variable on a customer button as a knob to change the volume, what is the command I have to enter there that can also be moved by mouse cursor?
geposted Fri 28 Aug 20 @ 9:46 pm
Perhaps I have not made myself clear.
HOW do you assign a command to a ROTARY CONTROLLER so that it can be rotated with the CURSOR?
This is especially about setting the Headphone Volume (Min to Max)
geposted Sun 30 Aug 20 @ 7:32 am
Why don't you just try it?
You've asked the question. You've been given the answer.
Custom controls are covered in the manual https://virtualdj.com/manuals/virtualdj/interface/decks/decksadvanced/custombuttons.html
geposted Sun 30 Aug 20 @ 7:40 am
I'm sorry if I'm bugging you with this.
But I'm using the Skin VECTRO from PhantomDeeJay and there's nothing going on with the knobs, no matter what I enter.
So I had to assume that the spelling I received was wrong.
Now I have programmed "headphone_volume" in the VDJ-PRO at fader, then it works.
So the error is in the skin VECTRO.
THANK YOU for your patience***
geposted Sun 30 Aug 20 @ 7:38 pm
there is effectively a bug in vectro and custom slider ^^
line 10031 in class="pnl_Slider_Custom" define
replace erroneous: action="custom_button 7 [CBNUM]"
with: action="custom_button [CBNUM]"
after what it run better (still the VDJ bugs with sliders and custom_sliders)
geposted Sun 30 Aug 20 @ 11:13 pm
