I would like to know if Virtual Dj has a option to set a hot cue on the first beat automatically when you load a track. Please, help!
geposted Sun 30 Aug 20 @ 7:09 pm
hello
go to Options on the AutoCue line select Cue/skyp silence
geposted Sun 30 Aug 20 @ 7:27 pm
I selected but hot cue on the first beat doesn't appear whe I load a track.
geposted Sun 30 Aug 20 @ 11:32 pm
You want to set Hotcue 1 always ?
Goto VDJ Settings->MAPPING tab, select Keyboard from the top-left list and then locate the ONSONGLOAD key below.
Use this action for the key..
repeat_start 'setc' 500ms & goto_first_beat & set_cue 1 & repeat_stop 'setc'
geposted Sun 30 Aug 20 @ 11:49 pm
Is there a variation of this to automatically set hot cue 1 at 0.00?
geposted Mon 31 Aug 20 @ 9:25 am
change the goto to
goto 0%
goto 0%
geposted Mon 31 Aug 20 @ 9:49 am
I just tried this and it overwrites if there is already a cue 1 by adding cue 2 at the same point (or rather it changes the original cue 1 to cue 2) which messes up any 'goto_cue action that you may have set on later cue points
geposted Mon 31 Aug 20 @ 10:09 am
This is weird, VDJ either crashed and reloaded or it just didn't like that action but it's no longer there?
geposted Mon 31 Aug 20 @ 10:22 am
