voici ce que ca me marque (Facebook has not received video signal from the video source for some time. Check that the connectivity between the video source and Facebook is sufficient for the source resolution and bitrate. Check your video encoder logs for details. If problems persist, consider improving connection quality or reducing the bitrate of your video source.
geposted Thu 03 Sep 20 @ 5:41 pm
Sounds like you might be using a very old version?
There been several updates fixing things since ...
Make sure you always use latest VirtualDJ ;-)
https://virtualdj.com/download/
geposted Thu 03 Sep 20 @ 10:11 pm
ok merci pour cet reponse mais cet version es uniquement pour windows 10 moi g windows 8 c comptatible avec ???????
geposted Fri 25 Sep 20 @ 9:27 am
