Hello VDJ World :)
Recently VDJ user (changed from the others)
Maybe someone can help me?
The short version:
Is it possible to send a Midi note to a plugin via settings/script by keystroke or custom button?
The long version:
I want to load certain presets from the launchpad into the plugin.
The plugin (Looperator)
https://sugar-bytes.de/de/looperator
allows the preset to be started by MIDI note.
( D#1 for example )
Is it possible to send this Midi note to the plugin by pressing a key?
The other version:
Launchpad
BUT_VERT_5
PAD_1_1 glows white
if pressed -> Load plugin "Looperator" in Player_01 EffectSlot_2
PAD_1 lights up red
BUT_VERT_5
PAD_2_1 lights green
if pressed->enable effect in Player_1 Effectslot_2
PAD_2_1 lights up red
if pressed again->deactivate effect in Player_1 Effectslot_2
BUT_VERT_5
PAD_3_1 lights green
if pressed->send Midi Note D#1
Can this be realized via VDJ script? Or do I need other tools for it?
My setup:
MCX 8000
Novation Launchpad MKII
OS: Windows 10
VirtualDJ 2021 PRO Infinity
I use the default mapping for the MCX and the Launchpad.
I have already searched the forum and the help pages, but unfortunately I didn't find anything suitable.
I hope that my question is understandable...
(sorry for the not perfect English)
THX 4U Help
The short version:
The long version:
( D#1 for example )
The other version:
Launchpad
BUT_VERT_5
PAD_1_1 glows white
PAD_1 lights up red
BUT_VERT_5
BUT_VERT_5
My setup:
MCX 8000
OS: Windows 10
THX 4U Help
geposted Wed 09 Sep 20 @ 3:53 pm
I don't think you can do it with VDJ alone, but you can use a script to pipe OS2L commands to a virtual MIDI device.
geposted Wed 09 Sep 20 @ 8:51 pm
Not sure for MIDI from VDJ,
"miditovst_active" in a way to pass midi through VDJ to the VST
in conjonction with a script to pipe OS2L commands to a virtual MIDI device.
the other solution can be to control the VST directly from VDJ :
the VST exposes 120 controls that can individually be used as a slider using "effect_slider" "LoopOperator" <slider> <value>
maybe the needed controls are accessible this way
geposted Wed 09 Sep 20 @ 10:02 pm
Thanks for your answers.
I'll take a closer look.
At the moment I have solved this quite unspectacularly.
The plugin remembers the last status.
I simply copied the plugin and started several instances.
at least one workaround but not the final solution yet :)
geposted Thu 10 Sep 20 @ 4:47 pm
