Been searching all over for hours trying to find something on doing this and can't find anything on it.
I want to keep the song titles with the crossfader action but eliminate the spinning discs et al. I have found the live.xml document in my computer but not sure what needs to be edited in it.
geposted Wed 09 Sep 20 @ 6:10 pm
Good evening,
click on interface config / tab
then you look at the bottom of the window where he tag video skins,
you can change video
example with videoskin waveform ribbon, if it is not present, download waveform ribbon in the video output tab
geposted Wed 09 Sep 20 @ 7:03 pm
You can also use the title effect
by downloading it in the expandable tab
geposted Wed 09 Sep 20 @ 7:41 pm
