Bought a new MC7000 used for 5 hours no issue, next day used after 10 mins distortion, switch off ok for 10 mins then distortion. repeated 3 times then run fine for 4 hours. Looked at firmware and it says i have current, using vdj windows 10. Do i just return controller? Firmware as shown Using Denon DJ MC7000 asio drivers. Have posted to Denon too, thought this bug was sorted?
geposted Sat 12 Sep 20 @ 10:29 am
Check in performance settings the samplerate make sure its set to 44k and not 48 or 96k as i had the same problem when i changed laptops with the 7000, hope that helps
geposted Sat 12 Sep 20 @ 5:48 pm
