Hello-
I've finally updated my VDJ and the default key setting is now showing both minor & major keys. I recall there used to be an option for setting the key display as only minor keys (I believe it was called "electronic"). Is this no longer possible? I found the old "minor key only" method extremely simple and effective for quick track selection & mixing. I dedicated several smart folders based around that detection. I understand music theory, including relative major/minor relationships, and do not want to start a debate. Just want to know if it is possible to switch between the two algorithms again. Thank you!
geposted Sun 20 Sep 20 @ 8:23 pm
Not I believe that was removed, since it basically meant "algorithm from v7" which was considered outdated
geposted Sun 20 Sep 20 @ 11:07 pm
