Under options, I can change the number of seconds before the end of song warning. However, I can't seem to find any other information about an end of song warning. How do I use this feature? Thanks!
geposted Thu 24 Sep 20 @ 1:18 am
Depending on the skin...some element of the skin will blink(timer,jog or the deck itself)
geposted Thu 24 Sep 20 @ 4:27 am
I'm not sure which options you have as a home user, but if you use the default skin, at the top of the screen go to layout. Select Pro, and you will see the outer ring of the turntable blink at the time you selected. It doesn't work in Performance for me, but the inner ring on my SR2 platter will blink, and that's all I need.
geposted Thu 24 Sep 20 @ 4:43 am
Thank you! I use "essentials" as it is more suited towards my purposes, which explains why I couldn't find it.
geposted Thu 24 Sep 20 @ 12:07 pm
