I have just purchased a Mixtrack Platinum FX contoller but I can only see the none FX version listed in my compatible controllers list.
I have VDJ version 8.3
How does one set this up ?...can I import the mapping ?
Thanks
Thanks
geposted Wed 30 Sep 20 @ 8:00 am
support for the platinumFX was added BUILD 5872 (2020-06-11) [v8.4]
I also believe that unit had to have new script actions for vdj so, even writing your own def & mapping file will have problems.
geposted Wed 30 Sep 20 @ 8:15 am
Thank you for your reply and help with this......disappointing there is no way to import a new controller map to you software
I guess they call that built in obsolescence.
Serato here i come !!!
geposted Wed 30 Sep 20 @ 11:07 am
If you have 8.3 you can upgrade to 2020 or 2021 for free
geposted Wed 30 Sep 20 @ 11:14 am
I don't see how it's built in obsolence. We couldn't know what was needed to support w controller that did not exist at the time...
geposted Wed 30 Sep 20 @ 11:15 am
ok..thanks...i will give it a go.
geposted Wed 30 Sep 20 @ 12:17 pm
