Working 0% or 100%:
effect_slider 2 1 & effect_slider 2 1 0% ? effect_active 2 off : effect_active 2 on
effect_slider 2 1 & effect_slider 2 1 100% ? effect_active 2 off : effect_active 2 on
Not working 50%:
effect_slider 2 1 & effect_slider 2 1 50% ? effect_active 2 off : effect_active 2 on
Any idea?
Not working 50%:
Any idea?
geposted Thu 01 Oct 20 @ 11:34 am
Probably not easy to get the slider at exactly 50%
geposted Thu 01 Oct 20 @ 11:46 am
effect_slider 2 1 & param_bigger "effect_slider 2 1" 51% ? param_small "effect_slider 2 1" 49% ? effect_active 2 off : effect_active 2 on : effect_active 2 on
that will give you a little leeway.
geposted Thu 01 Oct 20 @ 1:37 pm
or a little more closer (only 49.5 .. 50.5) (no need to read again just set slider value)
effect_slider 2 1 & param_multiply 10 & param_cast int & param_equal 5 ? effect_active 2 off : effect_active 2 on
geposted Thu 01 Oct 20 @ 3:07 pm
are you sure mate? that reads >.45 && <.55 to me.
geposted Thu 01 Oct 20 @ 3:43 pm
yes, math .. each in turn ;)
effect_slider 2 1 & param_multiply 100 & param_cast int & param_equal 50 ? effect_active 2 off : effect_active 2 on
geposted Thu 01 Oct 20 @ 4:17 pm
Thanks guys! It works :-)
geposted Fri 02 Oct 20 @ 9:45 am
