Hello, It appears that the Behringer CMD MM-1 is missing it's LED mappings for the Left/Right and Cue buttons, I'd really like to get access over these leds. I'm wondering if there is any way these mappings could be added to VirtualDJ, or if the controller definitions could be added to the controller list at https://virtualdj.com/wiki/VirtualDJ8%20Controllers.html so folks can have a jumping-off point to hack their controllers from. Personally, I had to jump through some hoops to assign the outer columns to different functions from the inner deck columns, which would have been much easier if I had a definition in the Devices folder that overrode the included definition (though was still easier than figuring out a definition from scratch ;) ).
geposted Fri 02 Oct 20 @ 12:42 am
The CUE leds dont miss mapping. They are simply un-assigned because by default they follow the true/false state of their buttons.
If you want to provide specific action, select the LED_PFL key in the Keys drop down list in VDJ Controllers tab., and provide an action.
geposted Fri 02 Oct 20 @ 1:05 am
