Answering this thread i realize the keyboard map i did for use with multiple time loaded tracks for use with stems could be somehow be usefull at least to experiment deeper with stems
https://virtualdj.com/forums/237726/General_Discussion/Vocal_Stem_thought.html
- drag/drop respectively loads track to all left or all right decks affected to crossfader side at a time
- load / play / stop / pitch / cues / sync / reverse / nudge / dump / slip... all apply to all stems of the same track at the same time
but not level / eq / fx / pad... in a way to make them stem specific
Of course
-more decks the skin handle more usefull it can be (6 8 or even 10 decks recommended but 4 can do)
- you need to activate stem configuration you want before to use it (select which track send which stem)
- resetStemsOnLoad have to be desactivated and faderStart and faderStartStop may help
the only thing missing (didn't figure out how to) is scratch by jog, scratch by dedicated encoder is working (i use the big vol encoder on my keyboard for that)
if some is interest in let me know
Of course
geposted Thu 08 Oct 20 @ 7:40 pm
