Im looking at the Numark Party Mix controller and was curious as to the compatibility of this device with Virtual DJ LE and if it comes with that software code.
geposted Sat 10 Oct 20 @ 2:25 pm
Takes 2 seconds to check. Anyway even if it did come with it I would avoid LE. It doesn't even have a proper browser and is restricted so much it's unusable.
It will work with the Pro version of VirtualDJ.
geposted Sat 10 Oct 20 @ 3:38 pm
Some come with VirtualDJ LE, some with Serato LE (light)
If yours didnt come with VirtualDJ LE, you can try activate at Numark and see if you are eligible.
https://www.numark.com/kb/article/2180
https://www.youtube.com/watch?v=tVyW4BQgjKY on how to register
VirtualDJ LE is quite a limited software though, and might be well worth the investment to get Home Plus (for home use) or the Pro version :
https://virtualdj.com/buy/
geposted Fri 16 Oct 20 @ 10:43 pm
