Hi All, updated to the 2021 version on MAC, and syphon output is not working anymore. Installed it again, same error...Any clues? Thanks!
geposted Sun 11 Oct 20 @ 11:23 pm
Forget my post, seems that syphon is not working with mathEngineShare GPU and experimental Use Metal enabled ;) disabling the Metal did the trick.
geposted Sun 11 Oct 20 @ 11:55 pm
Im having the same issue 2021 update .how did you get the syphon to work, please help me that would be amazing.
Dean
Dean
geposted Tue 11 May 21 @ 4:09 pm
Did you download the plugin?
https://virtualdj.com/plugins/?addonid=80982
geposted Tue 11 May 21 @ 4:20 pm
