_LI.jpg)
Wondering why these files have that square? They are regular mp3 files. Can't figure it out. They play fine.
Joe
geposted Thu 15 Oct 20 @ 5:37 pm
Some old user made skin that probably is missing some icon perhaps.
If you switch to default skin, what does it show then? Might be pre-calculated stems perhaps
geposted Thu 15 Oct 20 @ 6:04 pm
Seems to be specific to the Controller By Dennyo skins.
Easiest fix, comment out the custom icons code.
@staff this icon file needs updating -> https://virtualdj.com/developers/icons.png
geposted Thu 15 Oct 20 @ 6:18 pm
.png)
This is a shot of the default skin and its still there. Its in every skin too. I'm stumped. switched the Icon settings and that didn't change anything
Joe
geposted Fri 16 Oct 20 @ 12:01 pm
Doesn't look the same to me.
https://virtualdj.com/manuals/virtualdj/interface/browser/filelist.html
It's the overlay indicating that the file has precomputed stems.
geposted Fri 16 Oct 20 @ 12:08 pm
This is a shot of the default skin and its still there. Its in every skin too. I'm stumped. switched the Icon settings and that didn't change anythingBut ... its NOT there :) in the default skin all looks good ;-)
geposted Fri 16 Oct 20 @ 12:09 pm
Wow thanks guys I totally missed that.
Joe
Joe
geposted Fri 16 Oct 20 @ 12:15 pm
