Since update to Virtual DJ 2021,I had a lot of problems with videos freeze (only play videos),already try all different settings ,laptop video card NVIDIA GT 850 M 2 GB ,I'll be happy with the previous version was working without a problem. Please how to get back to 2020 version
geposted Sat 31 Oct 20 @ 10:35 pm
in settings, try set useLowPowerGPU to "high power"
See if that makes a difference.
Can also try the EA release that has a fix for improving sensitivity of lower/older gpu models when doing videos (with the stems feature that uses same card).
Try this installer, just run in to update:
https://virtualdj.com/download/pc/ea
https://virtualdj.com/download/mac/ea
(but I guess you have Windows, so use the "PC" link above)
geposted Sat 31 Oct 20 @ 11:03 pm
may depend on CPU too
i5 Gen2 (2400S @ 2.5GHz) with GT 520M works fine for me
try to modify settings : Performances ->
safeVideoDecode
useLowPowerGPU
or
maybe stems related :mathEngine Disabled
safeVideoDecode
useLowPowerGPU
or
geposted Sat 31 Oct 20 @ 11:04 pm
