Who edit track without recording, I wanna just create looping in the end of track and add some effects. For example I wanna edit track which 2 hours duration but i wanna only add some effects in the end . Did I need wait 2 hours recording this or I can edited only and save changed track? How use Virtual DJ just for editing tracks without recording all duration (for example 2hours) ?
geposted Tue 03 Nov 20 @ 3:16 pm
If it's two hours long, I doubt if it's a single track. More likely it's a DJ mix.
If you want to edit, then VDJ is not the best tool for the job. Use audio editing software such as Audacity.
geposted Tue 03 Nov 20 @ 3:33 pm
Some more answers
geposted Tue 03 Nov 20 @ 3:58 pm
Adding a loop at the end you can do in Track Cleaner.
If its just a basic loop you want.
VirutalDJ will then save a non destructive edit, that you can use (in VirtualDJ only).
https://virtualdj.com/manuals/virtualdj/editors/trackcleaner.html
Or you can use the POI editor to add markers in the songs to automatically trigger a loop, add an effect etc.
https://virtualdj.com/manuals/virtualdj/editors/poieditor.html
But both of these are for DJing live with the software, not for exporting/saving for other use (but you can of course record, but that is in real time, and would take the time it takes for the song(s)/mix takes to play through)
For editing audio files beyond the above mentioned things, you should probably use an audio editor, such as the free Audacity for example
https://www.audacityteam.org/
geposted Tue 03 Nov 20 @ 4:46 pm
Thanks for answer. I not using audacity because is not good for me.
geposted Tue 03 Nov 20 @ 5:11 pm
Why is it "not good" for you?
There are many other audio editing programs available.
VirtualDJ is not an audio editing program.
geposted Tue 03 Nov 20 @ 5:14 pm
