Hi guys, apologies if these questions have previously been answered but I wasn't able to locate any information.
I have a some questions regarding the IDJ pool (via VDJ)...
1- One you are subscribed, are you able to download the tracks (to your local hard drive/computer) or you will just be able to stream it....
2- Are you able to record your sets using tracks from that service (presumably they are being streamed).
3- Which plan does it include as on the IDJ Pool website it seems that not all plans cover all genre.
Many thanks
Many thanks
geposted Fri 06 Nov 20 @ 1:49 pm
1. Yes, you can cache tracks.
2. No you cannot record the tracks, as they do not belong to you. Same with any streaming (rental) service.
3. The VDJ service is not the same as any service that iDJ Pool offer directly.
geposted Fri 06 Nov 20 @ 2:07 pm
As for the content, you can try before buy...
Without the subscription you are still able to search, find and play (30 seconds extracts)
geposted Fri 06 Nov 20 @ 3:04 pm
