Topic: Numark NS6 problems (Virtual DJ 2021)
I have a Numark NS6 controller and i am currently using Virtual DJ 2021.The program works fine, but after a certain time when i want to select a song to play, then the one side of the controllers buttons does not work at all. Why is it doing this as i never had this problem before. I must resart Virtual DJ everytime.
geposted Sun 08 Nov 20 @ 9:39 am
Sure its only one side?
With a bad usb, or driver, it could perhaps lose power and the controller drop out in theory ...
But cant really see that happen just to one side
If its just one side, its perhaps something else, like selecting the side to work on a different deck (deck 2 vs deck 4)
The controller has a deck select on each side that toggles deck 1 & deck 3 ... and deck 2 & deck 4..
(but should be quite clear in the software skin to see what deck is selected)
Lastly it could just be dust and dirt . A fairly common problem.
But that wouldnt be happening only after a "certain time" perhaps
I have the same problem and haven't solved it yet.
