Hi there,
im playing a song on deck 1. Im generating a loop with a nice voice as example "U Cant Touch This", but i hear some Instruments in the background. So im acivating Stems and it sounds good.
Now i press the REC button and the loop moves to the sample recording database. If i fire this sample, then i hear the instruments again. So the recording was pre-Fx. Is there a way to record them post-Fx?
geposted Sun 08 Nov 20 @ 10:11 am
recording from a deck while in a loop is instant capture [not live capture], if you want it with stems/fx record from the mixers master tab
geposted Sun 08 Nov 20 @ 1:41 pm
If I do it from the mixers tab, then the start and the end is not exact enough. It a pain to cut it after recording and handle two files.
Is there a better way that I miss?
geposted Sun 08 Nov 20 @ 8:14 pm
There are several ways to do this. You can go to Options and search for effects and then select samplerShowEffects to Yes. Or you can REC to the sampler, then drag the sample into the deck and run the effects there, or on the master.
geposted Sun 08 Nov 20 @ 10:24 pm
use 2 action poi
geposted Mon 09 Nov 20 @ 1:57 am
