Would someone know the script for a custom button to turn a mic effect from a plug in on and off? The skin im using doesn't have it so im looking to create a custom button for it. Not looking for a while_pressed.
Thanks!
Thanks!
geposted Sun 08 Nov 20 @ 10:48 pm
For example :
Syntax being effect_active 'mic' 'name of the effect'
effect_active 'mic' 'reverb'
geposted Sun 08 Nov 20 @ 11:08 pm
select and active mic effect:
effect_select mic
effect_active mic
control buttons and sliders from mic effect:
effect_button mic 1
effect_slider mic 1
show the gui :
effect_show_gui mic
You can find some existing pads implementing this in detail:
djdad's MicFX : https://virtualdj.com/plugins/?addonid=80618
mine : Mic Aux Release Sampler FXs (MARS) : https://virtualdj.com/plugins/?addonid=81094
effect_select mic
effect_active mic
effect_button mic 1
effect_slider mic 1
show the gui :
effect_show_gui mic
geposted Sun 08 Nov 20 @ 11:10 pm
Thank you so much!
geposted Mon 09 Nov 20 @ 12:13 am
I cannot say enough how amazing it is to use Nicotux's, Mic Fx effect Pad: Mic Aux Release Sampler FXs (MARS) for easily adding effects to mic. (shown here with Reverb selected)
and found here in Extentions
geposted Mon 09 Nov 20 @ 12:32 am
Thank you so much for recommending that!!!..Awesome!!
geposted Thu 12 Nov 20 @ 3:27 am
