Need help deciding guys. Which is more vdj friendly? I tried vdj on the SRT a while back and noticed the auto pfl wasn't working, can it work on either one now? Thanks
geposted Tue 10 Nov 20 @ 4:21 pm
Both should work well ;-)
As for "auto headphones", on Pioneer controllers its usually made to operate with the channel cue buttons so you manually select what channel to pre-listen in headphones.
Try with autoheadphones and pflonselect both on in settings, if you have the controller at hand..
geposted Tue 10 Nov 20 @ 4:29 pm
I tried every way. Just couldn't get it to work When I load a deck from my keyboard I'd like that deck's pfl to light up and be active on the controller... The ddj 800 does that very well.
geposted Tue 10 Nov 20 @ 4:39 pm
There are enough posts on forums explaining the differences between the two.
No need to repeat the info.
However, the most important difference is Software (for DDJ-1000) vs External (for DDJ-1000SRT) mixer mode.
With External mixer mode, autopfl, Sandbox and a few other features don't work.
geposted Tue 10 Nov 20 @ 5:57 pm
I definitely recommend the DDJ-1000 over the SRT for Virtual DJ.
geposted Tue 10 Nov 20 @ 8:28 pm
