using a denin mc600mk2 with vdj but when broadcasting i can't use the mic through the mixer itself. Just does bit work at all.
I have to use it through the laptop but is not clear enough without dropping music to zero.
preference is to run everything through the mixer as I would if I was using my play out sound system.
geposted Fri 13 Nov 20 @ 10:47 pm
geposted Fri 13 Nov 20 @ 10:56 pm
You just have to route the mic back into the computer, so that it can be heard and broadcasted by VirtualDJ
Just flip the switch at rear side of the controller to "Rec out/Mic", and make sure VirtualDJ has a record entry in sound settings set to Denon sound card for that channel
Thats it ;-)
https://virtualdj.com/manuals/hardware/denon/mc6000mkii/advanced.html
geposted Fri 13 Nov 20 @ 11:31 pm
many thanks wi give this a try :)
geposted Sat 14 Nov 20 @ 8:15 pm
