Hi im struggling to get my controller working properly.
I have a pro license .
Numarc mixtrack quad 4 controller.
I connect it all up and all I get on the controller is both the play buttons lit up green. No other lights working like it used to .
I can use the virtual dj through my speakers but its less fun !
Can you help...
Jm
Can you help...
Jm
geposted Sat 14 Nov 20 @ 4:19 pm
Perhaps try reinstall/update the drivers...
And check if its properly detected and selected in Mapper settings in VirtualDJ.
Any clue or idea to when it started to happen? for example after a Windows update, or after using other hardware on same usb .. or anything that comes to mind, that might be the cause?
https://virtualdj.com/manuals/hardware/numark/mixtrackquad/setup.html
geposted Sat 14 Nov 20 @ 4:21 pm
ok i will take a loook at this
geposted Sat 14 Nov 20 @ 8:09 pm
Is it just a matter of leds ? Buttons, knobs, faders work or not ?
There are no drivers to install for Mixtrack Quad, it's a USB Class compliant device.
If the device is still functional, try a different USB port, USB cable or even a self-powered USB hub.
geposted Sat 14 Nov 20 @ 8:32 pm
Hi I tried it on a new laptop . It seemed fine but after 10 minutes went off. Just leaving the green play buttons lit up.
So I went back to my desktop device and its doing the same . I've got a pro license aswell.
I've noticed my mixtrack quad isn't being recognised by the computer . Just not sure how to change this ! I've tried various USB sockets etc
Jm
geposted Sun 15 Nov 20 @ 4:51 pm
Then you're not logged in, so VDJ cannot recognise that you have a license. It's just giving you a 10 minute trial period.
geposted Sun 15 Nov 20 @ 4:58 pm
I was logged in . At the moment it appears my pc isn't recognising the mixer :/ however the green play buttons are lit up when usb connected. Not sure how to remedy this yet
geposted Sun 15 Nov 20 @ 9:46 pm
You're contradicting yourself. You said it worked for 10 minutes then went off. If it worked, then it is being recognised. The 10 minute limit is applied when a controller is used without a license (for which you need to log in - with the same account you used to purchase your subscription).
geposted Mon 16 Nov 20 @ 10:30 am
Sorry just to clarify.
The device worked for 10 minutes on my laptop.
But I've had to send rest for repair as it needs 2 new usb ports fitted .
So when I put it back onto the desktop pc it wasn't recognised and didn't work properly;/
Jm
geposted Mon 16 Nov 20 @ 9:02 pm
check windows device manager, does windows see the device with no conflicts?
geposted Mon 16 Nov 20 @ 9:08 pm
