I'm using the default skin.
Here's my issue.
When using the essentials settings....the pitch will automatically adjust to track playing when start is pressed.
This does not happen when switching to pro.
I've played around with settings but stumped.
Thanks for your help.
Chuck
Here's my issue.
Chuck
geposted Sun 15 Nov 20 @ 1:38 am
with essentials as your skin, go to settings, check for autobpm match, check for smartplay,
geposted Sun 15 Nov 20 @ 2:07 am
Some skins set certain things themselves when they load. The Essentials skin has a total of nine 'oninit' actions that change settings in the background.
The only way to stop this behaviour is to edit the skin and remove those nine commands.
geposted Sun 15 Nov 20 @ 10:08 am
groovindj wrote :
not true I think they only set if setting has been unchanged.The only way to stop this behaviour...
geposted Sun 15 Nov 20 @ 10:35 am
geposted Sun 15 Nov 20 @ 11:11 am
In addition to the image above (where you can turn off these "auto" settings at the small settings icon next to the cue button), you can also find this in settings.
Look for autobpmmatch
geposted Sun 15 Nov 20 @ 3:54 pm
Hey Guys,
it worked.
Thank you!!!
Charlie
it worked.
Thank you!!!
Charlie
geposted Mon 16 Nov 20 @ 5:48 am
