hello dj`s
my sensitivity of tempo its too fast.
for example, I need to match bpm to 127.68, and the number going fast way too much.
need your help to slow down the sensitivity
geposted Sun 15 Nov 20 @ 5:15 pm
Try set the pitch range lower so that each incremental move on the pitch slider is less value
(keep in mind that some low-end cheap controllers, some faders are not that accurate or "sensitive". If so you might opt to map buttons instead)
geposted Sun 15 Nov 20 @ 5:58 pm
Tnx Rune! That's help
geposted Mon 16 Nov 20 @ 5:14 pm
