Guys,
I have a prerecorded mp4 file which is an hour long and I would like to stream this to Mixcloud, is this possible?
I know it can be done with jpg files using the slideshow option but not sure if it can be done with video file
geposted Tue 17 Nov 20 @ 3:57 pm
Can use the slideshow plugin with video files as well.. same way.
Make sure to open the slideshow fx settings, and click the "video" button
(Or you can play the video file at deck 3, or in the sampler. )
geposted Tue 17 Nov 20 @ 4:04 pm
Thanks Rune for your response, very helpful and I will test this out.
Just out of curiosity, why specifically deck 3?
geposted Wed 18 Nov 20 @ 11:35 am
Was just as example.. meaning a deck that you dont mix audio on.
So you could in just have the video file (background video) play at a deck not "in use", such as deck 3 or deck 4
But Slideshow video fx with video is probably better, even the sampler for that matter ;-)
geposted Wed 18 Nov 20 @ 3:23 pm
