I have question regarding this new feature
So while using a 4channel mixer/controller
setting EQ to EZ-remix or Modern EQ with frequencies on the inner channels (1&2) and stems on the outer (3&4)
it works fine when loading tracks on to deck 1 & 2. But when playing on Decks 3 & 4, we lose the ability to control stems - can only use frequencies
Kindly guide me if i have missed something here.
in short - how to control stems if one plays tracks on decks 3 & 4 ?
geposted Sat 28 Nov 20 @ 4:05 pm
If the controller/mixer applies its own Equalizer, you can't use the knobs to apply VirtualDJ Stems EQ. The only workaround is to use 2 Decks and the outer knobs to apply Stems to these Decks.
If your controller/mixer applies its own EQ, and need to use all 4 Decks, then your only option is to use an additional/side controller or Pads
geposted Sat 28 Nov 20 @ 6:24 pm
