Can we have multiple column sort? Like Sort BPM then hold ctrl and click key and that's sorted within the BPM sort?
geposted Thu 03 Dec 20 @ 7:27 pm
It already has that. Click one column then the next one and it will sort by first then second.
For example I clicked artist then BPM columns and it does exactly that.
geposted Thu 03 Dec 20 @ 8:07 pm
last click is always primary sort so Artist then bpm will result in a bpm sort with artist as secondary.
bear in mind bpm sorts down to the last decimal point even if you don't show decimal points
geposted Thu 03 Dec 20 @ 9:20 pm
but as already said... sorting by BPM is sorting float value, to acheive good sort against bpm better use filter folder with bpm range
geposted Thu 03 Dec 20 @ 9:34 pm
So can we have a second indicator appear so we can see that 2 or more columns are sorted. See in that pic I know BPM is sorting because of the arrow showing the sort direction but I cant tell which other column is sorted with it there's no indication. So its not done in the order you click like if I sort by bpm then key, key is the primary sort? so it 2, 1 instead of 1, 2?
geposted Fri 04 Dec 20 @ 1:03 am
Im good with my folder system I just wanted to sort a certain way.
you pretty much always have a secondary sort order, [other than resetSortOrder]
instead of trying to figure out what you're looking at just confirm it by clicking what you want to have, bpm clicked first, key clicked last
your primary is key, secondary bpm
geposted Fri 04 Dec 20 @ 1:50 am
what if I do key first and bpm second? Also can I hit a third column? Im just saying most software will show an indicator to show which columns are sorted and the direction of the sort. What's wrong with that? It actually simplifies it. You can also change the direction of the sort if you want to. If you're going do it, do it correctly sheesh.... yall make me feel like something wrong with me. But I think its the normal way of doing things.
geposted Fri 04 Dec 20 @ 3:27 am
