Ok so I have a knob that’s mapped as “loop_move” on my DJM T-1.
I also have a button that’s mapped as “stem_pad kick & stem_pad hihat & stem_pad bass & stem_pad instru”
Basically when I hit the button it mutes everything but the vocal.
I would like to map my “loop_move” knob as “stem_bleed” when I press the button and when I press it again it goes back to loop_move
Can someone please help me out?
Thanks for the time and info 🤙🏾
geposted Tue 15 Dec 20 @ 3:42 am
you can toggle a variable in your button
“stem_pad kick & stem_pad hihat & stem_pad bass & stem_pad instru & toggle 'loopnbleed'”
and use it in your knob map
"var 'loopnbleed' 0 ? loop_move : stems_bleed"
geposted Tue 15 Dec 20 @ 4:38 am
remap button to
only_stem 'vocal'
dial
only_stem 'vocal' ? loop_move : stems_bleed
only_stem 'vocal'
dial
geposted Tue 15 Dec 20 @ 11:43 am
Ok so I tried both of your scripts and the knob [which is an endless encoder] doesn't do anything.
the button works fine on both your scripts but again the knob does not work.
EDIT
I found the problem, its stemS_bleed, y'all forgot the "S" at the end of stem, lol!!
EDIT
geposted Tue 15 Dec 20 @ 12:47 pm
good catch, fixed posts
geposted Tue 15 Dec 20 @ 12:51 pm
Thank you guys!! Loving the STEMS feature!!
geposted Tue 15 Dec 20 @ 1:04 pm
