Having an issue trying to copy some files to an external drive. Only one folder out of 20 or so is giving me issues. I am using the File Operations option to preserve database info.
When I click "Copy to..." the word "copying" is displayed then the dialog box appears after a little bit. The dialog box says "Preparing to Copy" then disappears with no error message given and no files coped.
So far I have tried the following things:
Two different drives
Different computer
Renamed destination folder
Small batch copying
Copying files from a playlist
Using the "exists" filter to find broken files (all files came back as good)
Using Build 6156 on Windows. Razer Blade Pro.
Any idea?
Different computer
Small batch copying
Any idea?
geposted Tue 22 Dec 20 @ 6:52 am
SOLVED: Copy from the file tree worked.
I wonder why though! Figured I would leave this up in case someone else comes across the same issue.
geposted Tue 22 Dec 20 @ 7:07 am
