Hi guys,...
I have a big issue,... my VirtualDJ 2021 crash and reopen it all the time,...
Its installed virtualdj_2021_b6156_pc
It crash without any Error Messages,... i deinstall it and reinstall,... every driver are good and uptodate,... i'm so confused
You can see it here: https://drive.google.com/file/d/1l5bY24TggGnswJRnHIO5e8SxxvTRYHp2/view?usp=sharing
Can some Guys help me please, ...
Thx a lot
Thx a lot
geposted Tue 22 Dec 20 @ 9:17 am
Maybe go back a build and check if it's actually a VDJ issue
Another options is to raise a ticked with support - if you are online during the crash they will most likely have received a crash report from you
geposted Tue 22 Dec 20 @ 9:41 am
Try rename settings.xml in /documents/virtualdj/
Then start the software. Just to rule out its any bad skin or setting
geposted Tue 22 Dec 20 @ 10:08 am
first, thx for your help,...
i tryed with the version from 2018,... it doesnt show up, i the taskmanager it was to see, but not on the desktop,...
i tryed to install 2021 again, and now i have this when it starts up: https://drive.google.com/file/d/10-WIdvETo-riYGNDtN-jdM0mhhKJBPYl/view?usp=sharing
and it crash again,... :'(
geposted Tue 22 Dec 20 @ 2:03 pm
So guys,...
first,... thx for your help, now i fix it,...
i installed my system new, then is work fine,...
after i had install all my software i had the problem again,...
yesterday, befor i fall asleep, i rembermer one thing,...
now i wake up and i was testing,...
finaly,...
VirtualDJ have problem with "MSI Afterburner" and the "RivaTuner Stastics Server"
i use it to see my tempreratures when im gaming,...
i turn it off, and look,....
VirtualDJ runs perfekt!
Thx for all
finaly,...
Thx for all
geposted Wed 30 Dec 20 @ 8:22 am
