Forum: Wishes and new features
Topic: Right Click Virtual Folder Option.
It would be extremely helpful if we could right click playlists & folders in the library and have a virtual folder option from that.
Thanks!
geposted Wed 23 Dec 20 @ 10:48 pm
you mean add to?
Or show location or?
Not sure what you meant by "open from that"
What I'm asking for is the ability to right-click a playlist or folder from my library and be able to create a virtual folder from that. Instead of create the virtual folder, then go to playlist or folder and copy tracks from that. A simple right-click command would be awesome.
So nothing virtual about it? Just a link to a folder?
Because I believe that is what Favorite folders are for
You get a favorite folder by right-clicking and selecting "Set as favorite"
You can then mix and match your virtual folder and favorite folders (and filter folders) as you like
No, that’s not what I’m asking for. I’m mainly asking for a shortcut to create a VIRTUAL folder from a playlist.
