Dear Community
Please note that the 12/23/20 early update on VDJ 2021 will cause issues with the crossfaded on the midi controllers. I'm not sure why but after a few hours of fooling with it i decided to roll back to the previous version b6156 and problem fixed on all controllers... Hopefully VDJ will address this soon.
geposted Thu 24 Dec 20 @ 4:55 am
Which issue did you have and which controllers did you try?
geposted Thu 24 Dec 20 @ 5:33 am
They were Pioneer Ddj 800, Ddj 1000 & Ddj 1000SRT. The problem ended up being the early update i received today. Caused crossfaders to control the opposite deck and crossfader q start wouldn't operation correctly. Crossfader left controlled right. Crossfader right controlled left. Fader start worked backwards. Rolled back before the update tonight all problems fixed.
geposted Thu 24 Dec 20 @ 7:03 am
Check the crossfader reverse or "hamster" setting.
geposted Tue 29 Dec 20 @ 6:31 pm
